Few questions...
  • Few questions...
    I was curious how I would go about doing a PC fade, from one color to another, or how I could two tone. Is the fade as simple as filling the hopper with a different color as I spray? To do a two tone, do 1 part at a time and mask each side off? I did a search but couldn't find anything without going through every reply that has the word fade, two, or tone in it. Thanks for any and all info.
    Sorry Rob dont want to bust your bubble by not giving you a concrete answer,,,fades are the classic BITC_ , theres no easy way but to practice..Ive used card board to bounce the powder and it works on some things..you just need to mess around to get what your after..you start masking and you get hard line...not much of a fade..another thing you can try is to turn down the air...ALOT and work it to the depth by turning up the air slowly..
    Pro-Tech Powder Coating
    93976 Ocean Way
    541-247-8168
    [email protected]
    Gold Beach,Oregon
      everyone makes the in a different way
      what I do is
      start with the lightest color
      hang the part
      coat the first color from the top to the middle
      cure for 10-15 minutes
      hang the part the same way
      and coat the second color from the bottom to the middle
      cure for 10-15 minutes if a third coat will be used if not fully cure
      here is a picture of one I made
        hey Jt gotta ask somethin.......that cure for 10 to 15 mins..most of the powders i deal with start to jell around 250f........if you start the cooking and then stop it and start again you asking for trouble...? i mean the final cure rate.....the over all duribility cant be good if you interfer with the melt cure cycle....i know it will work........but...will it last?
        93976 Ocean Way
        541-247-8168
        [email protected]
        Gold Beach,Oregon
          Another thing, how do you not PC the raised letters on the valve cover? Just tape it out? Is there a way of PCing the letters/words a different color? Thanks guys for all your help
            I have a valve cover that has the letters V8 that will be black while I will do the rest of the cover a different color. I plan on doing the letters first, and doin a full cure then set it over night and then tape off the letters and do the rest the next day.
              Blademan I've never had any problems doing it or any complaints
              I've had some accidents after finish where some stuff falls of the tables or over them and they haven't chip off or scratch but as for a lasting coat I haven't had any compaints in almost 1-1/2 years I've been doing customers work.
              Robb letters are not powdercoated they are copy chromed with the flash cooper and copychrome plug and plate kit that caswell sells
              I chrome the letters and then tape them off with green high temp tape
              then I powder as normal and remove the tape after finish .
                Is it a haz. process like real chroming? Or is it a safe, do-it-yourself kit. Anyone have a link to that specific chrome kit? I did a search and got a bunch of different ones. I have no clue what to look for. Thanks, and sorry to be such a pain.
                  you need the cooper and the copy chrome ones
                  they are safe ( non fumes )
                  you can go to the electro plating area and read how to use them
