Techline Black Satin. Bake or Not?
  • Techline Black Satin. Bake or Not?
    CWith the Satin Black, I know it says Air dry but can you also bake it? I know it needs like an hour @ 500 I think.
    noob you can leave it air dry for 2 day's then the car will fully cure it or back it for an hour and leave it at that ...
      I am doing it with the motor out of the car so It will be sitting around for a while before it gets heat but I want to cure it right away. Thanks CS.
