tried it out for the first time. wondering if i'm doin somethin wrong. the pieces were new so i cleaned them, scuffed them, cleaned them again, and pre-baked. i used tropical orange on both(by the way--very bright color). the problem is on both pieces the powder came away from the edges not alot but enough to be noticed. Also its like you could see through the powder. should i have used a base coat first or was the PC on to thin?
First time PC over chrome and polished aluminum
I coat over chrome & AL all the time & have never had any issues. Powder certainly doesn't like right angles though! so I would suggest a slight bevel on those difficult edges, if it is feasible for you to do so. & if you can see through the finish, put it on thicker but if the powder you are using is a candy, then transparency is what you seek or what you will get!
nuttySouthWest Powderworx
Tyler Nutter
5054803934
www.swpowder.com
myspace/swpowder
[email protected]
sigpic
