i jut switched over my solvent tank to castrol super clean, works great no more solvent fumes in the garge and no more worry about fire. we do a lot of welding in the garage and i was worried about igniting the solvent (happened to my neighbor) so the super clean works as good or better than the solvent and no fire.
solvent tank
how do you heat it, and does that cause it to evaporate, and if it does evaporate is it just the water that goes or do you replace just the super clean, what ratio do you use. i was going to use it straight but i did not have enuff to get to the pump so i used 1/3 water and it work very well.Thier are only two real sports!
boxing and auto racing
all the rest are just games.
Drive it like you stole it!
