Help
  • dagobert
    I've got some of it, and have been happy with the results so far. It's not for structural repairs, but for filling pits, I think you'll like it.
  • jagboy69
    What is this Lab metal stuff Your telling me I can fill my cleaned metal where there are rust pits and get it smooth looking?? No way!!?? that would be awesome.. wHO has used this stuff Please tell :P
  • WAORacing
    Then the part is under cured. Try setting the oven on 400 and cure for 30 min. The best and safest way is to use a infared temp gun for getting accurate temps on the part.
  • lato
    it is scratching all the way through to the metal, thanks jamey
  • lato
  • DALE
    Is it scratching through the coating or just marring the finish?
  • Popeye
    Re: Help
    Lato,
    Sounds like the powder is under cured. You want the BMT base metal temp at 375 before you start timing.
    Caswell has Lab-Metal, works great for filling defects.
    IMHO
  • lato
    started a topic Help
    Help
    I am a novice at powder coating. I just bought a small powder coating system from Caswell. Also I bought black polyester powder. I sandblasted my first few pieces and coated them. Cured for 20 Min at 375 degrees. Pulled them out and let cool. Coating does not seem tough--they scratch easily. Am I doing something wrong? Do I need to use different type of powder? Is there some product for filling in rust pits on older material?
    Jamey
