Some may know this others may not but you have 2 version of the product on the market,
1st is AirCraft Remover LOW ODOR
2nd AirCraft Remover (with out the Low odor.)
The 2nd is what you want Low Odor means they replaced the real working Chem. Yes for removing plan everyday paint it may work great, but for powder coat removal good luck...
If you use #2 USE IN A VERY WELL VENTED AREA !!!!!!!!!!!!!!!
The frame I've been having a issue with cleaned up with in a few hours of using #2 and I used a whole gallon of #1 and well lets say it looked the same..
So just a FYI and Caswell if you sell #1 please start stocking #2....
