Is the drag (surface friction) on coating higher or lower than on the base metal? Meaning can it be used as a lubricant? It would seem that PTFE (teflon) would be a great additive for this, but I can not find any information if it is being done.
powder coat drag coefficient
Re: powder coat drag coefficient
Originally posted by ElectrathonIs the drag (surface friction) on coating higher or lower than on the base metal? Meaning can it be used as a lubricant? It would seem that PTFE (teflon) would be a great additive for this, but I can not find any information if it is being done.
http://www.caswellplating.com/aids/techline/ie.html#ie
Originally posted by Noob2PCOriginally posted by ElectrathonIs the drag (surface friction) on coating higher or lower than on the base metal? Meaning can it be used as a lubricant? It would seem that PTFE (teflon) would be a great additive for this, but I can not find any information if it is being done.
My thought were along the lines of a childs slide. If it could be coated and there was PTFE added to the powder then it would be more "slippery" than with just a layer of powder melted onto it. Of course, I do have visions of the scene in Christmas Vacation when they coated the sled.
Originally posted by ElectrathonOriginally posted by Noob2PCOriginally posted by ElectrathonIs the drag (surface friction) on coating higher or lower than on the base metal? Meaning can it be used as a lubricant? It would seem that PTFE (teflon) would be a great additive for this, but I can not find any information if it is being done.
Originally posted by remotestartdepotWhat are you thinking of coating??
Aaron
http://www.caswellplating.com/aids/techline/ie.html#ieI just saw that you wanted slick coating and I knew this was on the site so I pointed you that direction.
Well back to pulling motor so I can make it to daytona.
I recommend contacting Dupont directly. Since Teflon is their product, I'm sure they can answer your questions.Be sure to get ahold of their technical department.They often will custom formulate for the individual use but be sure to have your check book ready.It definately sounds like you need to be in the industrial market and not the hobby market for this project.
Originally posted by remotestartdepotHa Ha Noob. My Avitar is the coolest.
Kris
OH btw did you guys see my motor and how well it came out after I PC'd the intake and the Valve covers. I also have done the Carb but still have to take pictures of that. Still have a ton of stuff to PC since I dropped the cradle today. Tranny and suspension parts now. also going to do the upper trunk heat shield as well. I have to get this done before the Daytona Show!
Originally posted by Noob2PCOriginally posted by remotestartdepotHa Ha Noob. My Avitar is the coolest.
Kris
OH btw did you guys see my motor and how well it came out after I PC'd the intake and the Valve covers. I also have done the Carb but still have to take pictures of that. Still have a ton of stuff to PC since I dropped the cradle today. Tranny and suspension parts now. also going to do the upper trunk heat shield as well. I have to get this done before the Daytona Show!? I thought yours was PFI?? What happened?
Originally posted by remotestartdepotCARB? I thought yours was PFI?? What happened?
Originally posted by Noob2PCOriginally posted by remotestartdepotCARB? I thought yours was PFI?? What happened?
Kris
