Something you guys that are using either caswells or harbor frights gun should check out is the little brass ring above the water trap, this is connected to a braided wire, and a rubber cover over it,over time it will snap off from the wire...check it out and solder it so it has a good connect instead of the crimp on that it has..
gun check
