coating fiberglass
  • coating fiberglass
    anyone done any fiberglass parts ?
    I have a porshe fan cover and it's made out of fiberglass
    would it melt or crack under 400 for atleast 15 mins .
    nope ... it will melt ... clear coat basecoat it
      what do you mean ?
      coat it with clear, isn't it the same ??
        He means paint it using a basecoat/clearcoat system. You lay down a dull basecoat that is the color, and then cover it with a clearcoat. Pretty simple system actually.
        Kris
          ooooooh , that
            go to your local autobody supply shop and pick some up...
              the problem would be matching it to the candy blue on the other parts of the engine
                you might check the dupli-color line they have alot of nice colors to choose from, including illusion paint.
                Pro-Tech Powder Coating
                93976 Ocean Way
                541-247-8168
                [email protected]
                Gold Beach,Oregon
                  Do What I am doing, PC first them have the paint shop match the color. Most paint shops can match color samples. Some shops can also put it in a 16 oz rattle can as well.
                    You can get the blue mixed up (a custom color), and it will match perfectly.
                    I had my interior redone in my boat and when I went to get paint I took samples of the three colors into the paint shop. They took a prophet reading and the paint was right on. I think you need a 3X5 flat surface and a PPG platinum dealer.
                    Hope that helps.
