Hi, I am new to the board and new to Powdercoating. I have been lurking and followed the lead from a few thereads and made the skeleton for my "to be" oven. My question is, I picked up roof flashing (I am going the cheap route, this will be for personal use only) and it is quite thin. I did get the steel roof flashing but was courious if it will be too thin for oven use. I used the metal studs for the frame and it will be insulated with roof flashing as skin on either side of the frame. I don't mind a little warpage as long as the oven will function. I was going to do the automotive sheet metal but it is quite expensive.
Comments? (PS, I did a search and could not find info weather or not this would be a problem)
Thanks in advance.
Thanks in advance.
