Techline Coating Question
  • Techline Coating Question
    I have a customer who is wanting to Ceramic Coat a Prrt. I have no problems with it except I am not set up to polish the silver/chrome color after coating. If I was to coat them and ship to him would it polish up ok after say a week or so? Also anyone know if you Chrome a Valve cover, will it withstand the Oil?
    TIA.
    The only way to get the cromelike finnish on Techlines Cermakrome is to use a vibratory polisher. Is could work to do it by hand also, the coating is mainly based on aluminum particles så use the same tecniques as for polishing alu, but you cant beat the finnish you get in a vibrator.
    Not sure what you mean by polishing it after a week, but out of the oven its more like a beige matte surface that need to be treated some way. An alternative way would be to glassbead blast it at very low pressure to get a pretty nice finnish on it, use large size glass for better result.
    And yes, it can handle every chemical you got in a car
    My webserver is down but i can mail you some "right out of oven" pics, drop me a mail at [email protected]...
    WEIRD Performance & Coatings
    Sweden
      What the case would be is:
      1. I am coating it with Techline. I will not be polishing it.
      2. I will then ship to the client/customer.
      3. Once he gets it he will polish it up.
      Will the time in Transit cause the part not to polish up when he does it?
        I work with ceramic on a regular basis
        you must achive a thick coat before curring or you can sand trough the coat polishing and you'll have to start all over again.
        after cured you can treat it like polishing a piece of aluminum
        I use a vibratory then hand polish it with a buffer .
        vibratory has the advatage of getting into hard to reach areas and it's fast 10-15 minutes
        after cured you can polish it any time you need to
        I some times cured all parts on monday and polish the last one on friday
        you won't have any problems sending it by mail.
          Ok, how do you vibrate polish something like a set of headers?
            realy big tub! i plan on using a washer as a base for mine.
              Yepp, takes a big tub to fit all stuff we get in for coating, but the downside is that the media isnt cheap.
              Sweden
                Walnut shells work ok and is cheap. Dang I wish I still had that link to the place that had 50lb bags.
                  When vibrating Cermakrome you cant beat Microbrite balls, not cheap, but last long and gives outstanding result. No need for further buffing at all.
                  Sweden
                    I just need to figure out what/how to set up the motor so it vibrates and not spins.
