HI Temp
  • HI Temp
    Anyone have a problem with the Hi Temp powder comes off of the part being powder. I can't get it to stick very good. It does cure at 400 like other powders? I did a pipe 3 times and it stills comes off to easy.
    WARCHILD
    the high temp powder
    I use needs to be cured at 500 (part temperature) for 15 minutes
    I always pre heat the part to 150 then coat
    haven't had any problems so far.
    still techlines ceramic coats are far better.
      Ok I will try it at 500. next time.
      WARCHILD
        Re: High temp
        Hey Warchild:
        I have been using Caswell's Burner Black, with great results. The cure temp is 450 for 15 minutes. Are you making sure the product is prepped correctly?
        Bob
        www.capecodpowdercoating.com
          It's been prepped like all the other stuff I have done. I think maybe it has been under cured. thats what it seems like is wrong. I will try it at 450 first then at 500 if 450 don't wrok. I will try to powder it on Sat. Thanks.
          WARCHILD
            Well my HI Temp powder is junk! It don't work. I cured parts at 400 then 425,450,475,500,525 and 550. at 15min each and still nothing. It's not getting as hard as my other powder coated parts. I can just tap it with my knife and it comes off so easy and on the plane powder coat I can hit it all day real hard with my knife and it will stay on it. This HI Temp powder seems like it's not cured the way it flakes off so easy but after doing a part in the oven at 550deg I think something is wrong here. PS. I just put this face on here because I thought it was funny---->
            WARCHILD
              it might be something wrong in the prep
              you are not supposed to use any liquids after sand blasting the part
              outgass
              sandblast
              clean with dry clean cloth
              quick burn with torch( to burn small cloth hairs left on)
              coat
              this is the way I've been ussing and it works fine for me.
                outgass
                sandblast
                coat
                  I blast it then wipe with dry cloth. thats how i been donig it.
                  WARCHILD
                    i had the same problems with hi temp powder 1 time ever since then i use techline
