Here are my oven plans that i quickly drew up. I have all the parts except for my elements wich are on back order. It is 6ft wide 4ft deep and 3ft tall. Panel costruction is 20gauge galvanized 3-5/8" thick, insulation is Roxul rht60 6# density foil backed mineral fiber rated for more than 900 degrees. I have a therm-coil temp. control, contator and 4 3100watt elements , and two small fans one on each side.
I have a couple of more questions for you guys:
1. As you can see in the pick i want to put a removable panel in the center.
The idea behind this is that i would like to have a switch so i can turn off
the two elements on one side and use only half the oven for small
parts. Is it possible to have a switch turning off two elements?
2. Since the therm-coil is only rated to 30 amps i will have to hook up
a contactor. Here is the wiring diagram that came with my thermcoil
for single phase when load exceeds rating of thermo stat. Can
someone explain to me how to wire this up? I dont understand the
control voltage and the line load part.
Thanks again to all you guys for the helpful feed back
