SUPER CHROME ???
  • SUPER CHROME ???
    Finally tried my hand at powdercoating and loved it. My question is do I need the clear the super chrome? I did as per recommendation but it dulled the look too much for my taste. Would it hurt if I didn't clear the super chrome. I'm getting ready to do my intake manifold and would like to keep it as shiny as possible. Thanks for any info.
    you need to use a super mirror clear cantact caswell direct i am sure they stock it if not i know they will be able to get it for you
      Just like custom said,(glad to see you back chuck),
      you need a clear on it. The chrome pc is great but just wont last under certain conditions without the clear. Put a coat of clear on it. Find the clear with the highest gloss rating. Check to see what caswell's and go from there.
        I used the clear that Caswell had listed. It was their standard clear. I didn't know they had a super mirror clear and didn't see it in their product line.
          We only have one Clear.
          You need to consider either:
          you have applied too much powder, or there is a problem with the cure time or temp.
          Post more info and I'm sure your problem will be solved here.
