wavy finish
  • wavy finish
    i have been having trouble getting a smooth finish. the finish has a wavy look to it. so how can i get a smooth finish.
    You way be putting it on too thick. Does it look like an orange peel? If so, it's too thick.
    Kris
      it's an orange peel look. i have reduced the amount of powder i put down but it's still there. it's more noticable on darker colors especially red.
        How are you curing it? What temp? How are you checking this temp?How long are you curing it?Is there a clear coat?
          curing to directions of the powder.oven temp is accurate i am able to maintain my heat with in +/- 7 degrees. as far as part temp i just allow plenty of time to cure. just doing some small sample pieces right now trying to get a smoother finish. no problem with the clears.
            I stay down around 325 for 25 min to get a smooth finish. This allows the powder to stay in a wet state longer.Sometimes waves come from the part curing too fast.The powder cures before it has enough time to flow properly.
              dale, tried the lower temp with a little better result. can you get the same type of finish with powder that you can with paint.
                Watch how thick you apply the powder and the cure time.
                This is Candy Apple Red ( Chrome base) ..
                Jim S...
                Jim Shuster
                www.backyardpowdercoating.com Sold.....
                www.chrissys68mustang.com Hobbie
                www.photogserver.net Web Hosting.
                  On rounded surfaces absolutely, larger flat surfaces get harder to get that paint look.You can get an oem paint quality simple enough but going for a perfect finish is simply experience.
                  As an added note I forgot to ask earlier, are you media blasting the part?I'm assuming you are, most people do,try sanding the part after blasting with a fine paper.Just remove the high spots don't go overboard.You don't need to sand it perfectly smooth.
                    thanks for the info i'll give it a try.
