Oven Wiring
  • Oven Wiring
    I know this has been beat to death. I just want to ask if someone can email me a wiring diagram. I will be gutting an old oven for the controlls. Will be doing 4 elements. I will be upgrading my outlet to 50 amp circut. please email to [email protected] (remove the nospam.)
    Also I am planning a 4'D x 3'W x 6'H inside dimensions, will 2 on each side be the best placement. I also plan on using just Vents on the bottom and top for air flow.
    thanks a lot guys.
    OK no one sent me anything but I found this in the album. Would this work the same with 3 or 4 elements? also what does the n/o mean in the drawing?
      That would work provided the contactor is rated high enough to carry the current for 4 elements. The N/O means normally open and looks to be a regular on and off switch.
      Leo
      www.tinmans.net
      "Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming -- WOW--What a Ride!!!" ----- Unknown
