I just built an oven out of an old railroad signal box, six feet tall, 3 foot wide and two feet deep. I put owens corning insulation on the outside and then 4x8 sheets of durorock around that. I am wondering when hanging parts up to bake will the powder coat run off when heating. I have to get my wiring done next and will see if everything works.
will powder coating run
Re" Will Powder coating run?
I've never seen it run so much that is would drip off! In fact, run's are not very common.
Good Luck
Bob
It will run with a bad ground or none.PC ran like a scared rabbit. In the past I have seen an occasional drip where I applied it on the heavy side trying to get into a deep corner or crevice.
