Harley Cylinders
  • Harley Cylinders
    Ok...I did a search and read about what people have done to coat cast iron cylinders.My question is the heat disipation.Are the cylinders really affected that much with PC?1 more...will regular powder be sufficient or will I have to use high temp?
    Thanks,
    Buzzurd
    Regular powder holds up fine as long as the motor is operating properly.Heat won't be effected enough to worry about.
