sandblasting
  • sandblasting
    were do u people get what ever u use to sandblast from like the sand and what is the best stuff too use if not sand
    I have been using Alum Oxide and it has worked just fine for me. I have to pick up some glass bead for detail/polishing work soon.
      DON'T USE REGULAR PLAY SAND. THE SILICATE IS VERY BAD FOR YOU TO INHALE.
        You can try checking with your local equipment rental business. Most that rent large blasting units also carry and sell grit at a fair price.
        Today's mighty oak was just some nut that held it's ground !
          Glass bead is one product that leaves a very smooth finish that doesn't require any further work.
            Why don't you go to : www.caswell.com and purchase it caswell stocks a great media for blasting .... show them some love!!!
              Yes, but shipping would negate any saving for most of us.... 50lbs to Fl would kill me. Besides, when I want love I just go buy playground sand and then post about it here and FEEL all Kinds of Luv!
              BTW, thanks I did not know they offered that. will keep that in mind.
                trsick those are great prices where are you?
                Thier are only two real sports!
                boxing and auto racing
                all the rest are just games.
                Drive it like you stole it!
                  regular sand isnt too bad if you wear a good respirator and your blasting outdoors
                  still though play sand is designed to trap moisture and hold shapes (sandcastles)
                  which makes it a pain the butt to use in a blaster
                  lowes sells a quickcrete medium sand industrial white sand that flows much better and leaves a great profile at 2.94 a 50# bag which is just a tad more than play sand
                  either kind of sand though ithinkk is really slow compared to alminum oxide
                  and blasting outdoors can still get really expensive since your losing all your sand so eventually its way worth building a booth and recycling aluminum oxide
                    glass
                    glass bead isnt the best stuff to use even thought its fast and leaves a decent profile
                    it closes off the pores in the metal which can make your coatings adhere a little poorly
                    and be a lot less durable for high abuse pieces like dirtbike and four wheeler parts
                      Re: tsc
                      Originally posted by sickboy57
                      tractor supply usually carries red garnet ,aluminum oxide and glass bead.
                      this stuff is just too heavy to mail order youll pay way too much after shipping charges
                      those are some crazy good prices $10 for 100#
                      ive yet to see anywhere crry the stuff for $25 for 50#
                      is the local auto store a franchise?
                      what company is this?
                      i mean for less than $25 for 50#
