caswell hobby gun question
  • caswell hobby gun question
    I have the caswell hobby gun. On the bottom of the gun there is a plastic plug between the end of the gun and the trigger. I have taken it out and cleaned it after spraying, my question is, what is this for. Is it to adjust the spray. I noticed that there is an "O" ring on it and it is getting kind of beat up from being taken out so many times. I have lost my owners manual to this gun so any help would be great. Thanks
    You can buy a replacement O ring at most parts stores. If I remember correct it does effect the flow. I remove mine all the time to clean the gun.
      I have the starter kit, and the manual says it is a regulating screw. I have not tried the gun yet, so I am not sure what it regulates.
      What kind of luck have you had with your gun?
        so far it works great. Everything I've done looks good
          that is good to hear, any pics?
          What kind of curing oven are you using, I will trying to use a home oven.
          ca
