Would pressurizing my cabinet really give an increase of 4-5 times faster as they claim?I have about 130 lbs. continuous pressure and good media flow.But I am considering adapting my pressure pot to the cabinet.Would it be worth it? Thanks Steve
Pressurized blaster?
We normally use an ordinary siphon kind of blaster in our cabinet, but when i get reall nasty things to blast i use the pressurised blaster pot hose in the cabinet. You cant even compare them, its like you upped the pressure by 200%.... so on stuff that have a few coats of urethane like paint on it, like some wheels, yes, i would say 4-5 times faster minimum since the siphon dont even bite on it...WEIRD Performance & Coatings
Sweden
Re: Pressurized blaster?
Hey Zpider:
I have both the syphon cabinet & a walkin booth with a pressure pot. Seems I always have trouble with the pressure pot either using the media to fast, & or clogging, even if I use strickly virgin media? What are you doing? How long & how much media does it take you to blast a set of wheel (2 @ 15")?
Anything I can do to reduce prep time is a good thing!!
Thanks
Bob
Whells are a pita, some have urethane paints that wont come off easy, in hours, well, all from half an hour to half a day on 2 wheels. The pots are tricky to get adjusted for the right flow, take a bit of jiggling to get it set up.WEIRD Performance & Coatings
Sweden
