Dip Tank
  • Dip Tank
    Has anybody set up a dip tank for stripping parts?
    I have dipped small PC'd parts over night in a bath of aircraft stripper with great results.But 55 gals. of the stuff would be costly.Any other chemicals more reasonable for this purpose?
    Nobody uses a dip tank?
    How do you strip your pC'd parts? Steve
      I have been doing the same thing as you.
        Re: Dip tank
        I burn it off!
        Bob
        www.capecodpowdercoating.com
          JASCO floor stipper from Home Depot works for me, I picked up some DADS stripper from walmart with a plastic spray bottle. So you should be able to get a plastic tote from walmart and put a few gallons in it to soak the parts. Berrymans Chem dip works as well.
          paul
            That Berymans Chem dip at Avance Auto was about $55 for 5 gals.
            How much was the Dads Stripper ?
            I'm up in the mountains so a trip to any where takes awhile.
            How well did the Dad's stripper work on powder coat?
              DADS stripper
              Hold on to your wallet when buying DADs stripper, 1 gallon is $17 to $20. 1 quart cost $6.95 at Wally World but it works damn good.
              paul
