DIY fluidized bed?
  • DIY fluidized bed?
    I am going to be coating a bunch of small parts for a hotrod project in one color and was wondering if anyone had suggestions or plans for building a small fluidized bed.
    Any input is appriciated.
    http://www.pcfpowder.com/doit.html
    Is that what you're looking for?
      Fluidized Hopper
      Check out item 7508784520 on Ebay. This has a 6" ID, which should be ok for small parts.
      Gary
        Re: Fluidized Hopper
        Gary
        Can I run those off any compressor with a moisture trap and regulator?
          Thanks.
            Fluidized Hopper
            I use this hopper to supply my Nordson gun (multiple hoppers for color changes), but have also used it as a fluidized hopper. I run a water filter before my paint air system and a low pressure regulator before the fluidizing hopper. I run 5 to 7 psi on average. Preheat temperature determines paint thickness (hotter = thicker). Hopes this helps.
            Gary
