DIY fluidized bed?
  • Motorhead
    Fluidized Hopper
    I use this hopper to supply my Nordson gun (multiple hoppers for color changes), but have also used it as a fluidized hopper. I run a water filter before my paint air system and a low pressure regulator before the fluidizing hopper. I run 5 to 7 psi on average. Preheat temperature determines paint thickness (hotter = thicker). Hopes this helps.
    Gary
  • Bernert
    Originally posted by Popeye
    http://www.pcfpowder.com/doit.html
    Is that what you're looking for?
    Thanks.
  • Bernert
    Re: Fluidized Hopper
    Originally posted by Motorhead
    Check out item 7508784520 on Ebay. This has a 6" ID, which should be ok for small parts.
    Gary
    Can I run those off any compressor with a moisture trap and regulator?
  • Motorhead
    Fluidized Hopper
    Gary
  • Popeye
  • Bernert
    started a topic DIY fluidized bed?
    DIY fluidized bed?
    I am going to be coating a bunch of small parts for a hotrod project in one color and was wondering if anyone had suggestions or plans for building a small fluidized bed.
    Any input is appriciated.
