HEELPP....Some opinions would be helpful...Curing
  • HEELPP....Some opinions would be helpful...Curing
    Hi...Im looking for a way to cure atv and motorcycle frames...i have already bought the P.C. Gun from caswell and need an IR Lamp to cure the powder for the frames... Has anyone had any sucess with Ir Lamps and frames...
    I also called caswell and asked if the Ir lamps they had would cure the powder on my motorcycle frames and she had told me no...so i need some help... thanks
    Hey Sezer, I'm not an expert, but it should work with a 2000 and above watt infrared lamp used in a makeshift box with reflective material. I have yet to try it. I have a 1500 watt lamp and in a search on here I found members saying that 1500 isn't enough. I hope it is, but if not then one day I'll get the right wattage and have a go at it, for I plan on expanding the sizes of items I do too! Oh yeah don't forget to have a infrared laser gun for making sure of constant emps for curing. Or at least just to know the temp.
      Re: HEELPP....Some opinions would be helpful...Curing
      I have the Triple Mr Heater and it works great for big stuff that wont fit in household oven. It runs off of 20# propane bottle. It is a must to have a IR thermometer.
        I too use a propane lamp that I purchased from another vendor. I have P/C'd 2 motorcycle frames and both turned out great. They just took a little longer to cure because of having to move the lamp around the frame and on both sides. And WAORacing is right, the I/R thermo is a must.
          thanks guys...think i might try the propane method...
            Do you guys leave the heater on one side til cure,then put it on the other side for cure? does the part get to temp by placing it just on one side? I have never used my Mr. heater for curing. Just curious.
              Depends on shape and size of object being cured. Me and a buddy powder coated a roll cage in his mustang about a month ago with the mr. heater and another little heater and heat gun. The hardest thing was he left the windsheild in and the rear side glass in. Now that was an experience. I used a few wet towels to keep the glass and body of the car from getting messed up.
