powder coating over powder coat?
  • Crimson
    Re: powder coating over powder coat?
    yea I see that message getting deleted pretty fast. This is a caswell board I do not think they would like you trying to get business off it.
  • FSTFBDY
    There shouldnt be much of a problem if the part is reheated again.
    Just think of it as a 2 step coating job anyways. like all the base/clears.
    Shoot it hot and you shouldnt need a good ground. But keep a eye on how much powder you lay on the part.
  • kchotboat
    I have done it before, I used a friends shop with his progun. First I went over the part with steelwool and also baked it 10min longer than the powder called for.
  • corecoatings
    I have had luck just using the actual first hook through the whole process. Obviously it takes a bit more on a second coat being that it is a 20kv gun.
    Once that hook is in a hole, it should be a decent contact point. Good luck!
  • customandsound
    just scuff it with 320 and in a spot that is not noticeable i scratch it down to the bare metal to get a good ground. and i test my arc it the arc is light i turn the air down to 8-10 it i got a good arc i shot as i would a fresh part.. it the arc is to light with the hobby gun i will switch over to my pro gun and get it done...
  • Blademan
    try a new ground point and re-heat the part, i like to use around 150 .
  • corybarta
    started a topic powder coating over powder coat?
    I know this has been disscussed before, I have read that you can powder coat over powder coating by sanding it then coating over it. I have tried this and the new powder does not stick to the part. I have even used my sand blaster to roughen up the surface and it still wont stick to the part. I find my self having to completely blast the part down to bare metal again to get it to work properly. Any help would be appreciated. Will the powder get and a charge threw the old powder
