expanding a kitchen oven termporarily
  • expanding a kitchen oven termporarily
    For what I do, your typical kitchen oven will work fine. There are just two people that I want to help out... and the part just wont kit in the oven. Not by much.
    Has anyone built a little extension to their oven? Did it work out ok?
    I did that avery long time ago
    I used 1/16 metal sheet and 1 inch kanuf insulation
    worked great
    I opened the oven door and placed the insulated box on it and push it about 2 inches inside the oven for a tight fit .
      Re: expanding a kitchen oven termporarily
      LOL, I did that & it worked great. I used a sheet of "Certanteed Ultra gold duct board". Made a box using duct tape to put it all together, that sat on the door in the open (down) position. I had to block the stove top elements where the oven vented & put a hole in the front to draw the heat towards the front of the box. It worked awesome.
      Good Luck
      Bob
      www.capecodpowdercoating.com
        Re:Powder Coating Questions
        Check tis out. About 1/2 way down he shows how to make a household oven bigger. I did it & it worked great until I built my big oven
        Bob
