yesterday I coated some parts. I hung them up like I usually do and heated the part up with my propane torch to get rid of any moisture. after that the part was still quite warm so I coated it, everything went on great. I went to disconnect everything and discovered that I never hooked up the ground clamp to the part. The heat itself must have made the powder stick. I put it in the oven and it came out great.
My question is if there was no electricity running threw it will the coating job hold up very well. Thanks
