As some of you all know I ceramic coated my Exhaust system on my Fiero. Well I got it running last weekend and got to drive it around a bit today and MAN waht a difference. The under lid Temps are down a ton! compared to even the old 4 cyl I had in there. Even after running for a min I touched the Exhaust Manifold and it did not burn my finger! it was hot but not sear your skin off hot! Thumbs Up and I recommened it for any Exhaust Parts!
Ceramic Coating WORKS!
Worked with Techlines products for 1.5 years now, and yes, they do the job rightWEIRD Performance & Coatings
Sweden
This is the post I've been waiting for, I am going to do my snowmobile pipes in the satin black that way I can remove the heat shields and save 3.5 pounds of weight. I am glad to know that it actually keeps the temps down. I bought a can of the satin black from caswell about two months ago and am going to apply it this weekend. thanks
Originally posted by Noob2PCOriginally posted by CaptainChauncyHow did you end up polishing it? I have had a hard time getting ceramic coatings to shine.I fixed that and never worry about it. I Only use Satin Black!
I think I am going to have to order some satin black to try. Any pictures of how it turned out?
Originally posted by jtagger19hmmm , satin black doesn't come out like that , that header has clear or some type of oil over it.WEIRD Performance & Coatings
Sweden
did I do it right, I applied the black satin coating on my smowmobile pipes this weekend. I blasted the pipes using garnet as a blasting media. I then hung the parts and used my hvlp gun a put on a very this coat. I then baked the pipes at 450 degrees for 1 hour, this is all the hotter my oven gets. I took them out and let them cool down and everyting looks great. Does this stuff really work, it seems like a this coat of paint would not hold heat in. any vote of confidence would be nice this stuff is expensive. thanks
by the way what did you use as a silicone spray.
As i said, ive been using it long enough to know it really works. Use any siliconespray you can get, here in Sweden we dont have the same brands as you guys...WEIRD Performance & Coatings
Sweden
