Peeling off
  • Peeling off
    I did some parts that were assemebled. Yeah I know!, but anyhow. I had to seperate them the PC is peeling off. If I try I believe I could peel the entire part and end up with a Skin. Did I under cure the parts? It was one of the first parts I did and not sure if I let them get to temp.
    sounds like under cure ,
    I have found that if stripping under cured powder with aircraft it melts like liquid , if it strips like rubber it was cured .
    I have be told that you can fix under cure powder by repeating the cure process.
    but I haven't tried yet.
      thanks, that is what I though. Well it is installed and running, I am not pulling it just to heat it again! Im gonna drive it now.
      It was early and I have learned a lot since then.
