Stripper...
  • Guest's Avatar
    I am sorry i edited this topic. Please support Caswell when it comes to stripper. This is there forum and it is here to help us. The other companies Don't Have a forum to help and offer support to us.
  • VPC
    Auotbody supply stores carry a paint gun cleaner in 5 gallon cans with a little dip basket that works great.about $100 a can.Drop PC'd part in come back an hour later and the powdercoat just falls off.I'm up to 20 gallons now in my strip tank.Buying a can every couple weeks or so.I want to end up with a tank full big enough to drop a motorcycle frame in.
    Can't help it,I'm lazy and hate stripping parts.Especially PC'd parts that haven't turned out right and have to be reshot.
    I've tried just about every stripper out there.The Aircraft stripper being about the best for a brush on type.But the dip tank I now have is still way better.
  • upncoming
    Re: Stripper
    Originally posted by trsick
    Originally posted by upncoming
    Aircraft Stripper is the way to go.. very easy to work with for me every time i had to use it.. but i still haven't found out where to get it in gallons..
    I have found gallon cans at Autozone & Walmart ($19.99)
    Good Luck
    Bob
    hey thanks i will look for it next time im there. i never thought about looking for it in walmart.. iv been going to pepboys for the spray cans lol..
  • trsick
    Re: Stripper
    I have found gallon cans.
    Good Luck
    Bob
  • upncoming
  • trsick
    Re: Stripper
    Try Aircraft Stripper Try to get the one that is NOT "Low Odor" (works better), but both kinds work well. I buy it in 1 gallon
    Good Luck
    Bob
  • speeddemonrodsteration
    the best stripper I've found is called Gasket Stripper! It works to remove PC, paint, the toughest silicons, mother in laws, ect. If this stuff doesn't at least loosen it up it wasn't meant to come off!
  • Blademan
    them Guru's surrrrrrrre know there stuff for sure....hey Dale !!
  • Noob2PC
    MAn you got my Attention with the subject of this one!
  • KZjim
    started a topic Stripper...
    Stripper...
    OK.. so I bouthe the stripper from Caswell.. and it worked good... but it didnt last long because of mulitple applications...
    So i ended up with the Kleen-Strip product.... this stuff works great! it bubbled up and i wiped it off with a paper towel...
