Just a small blurb about the swivel hooks. It seems that if you ground to a bar and hang the swivel on said bar the grounding is less than desireable.
Anyone have the same symptoms?
I only write this because I checked continuity to the bottom of the hook to the bar and it was erratic. Could it need a good cleaning and a qucik beating?
