Need info on powder for 67 Firebird Rally 2 rims
  • Need info on powder for 67 Firebird Rally 2 rims
    From what I gathered from the customer there are two color grays. One light one darker.
    Anyone know which powders represent the colors for these rims.
    Also after doing the triangles, he has a mask kit for them.Probably not high temp. What are the chances of leaving them and cooking then removing and wiping remains off? Any thoughts? Anyone? Powder on.........Andy
    them insterts will come off the wheel. gm uses a argent for the color ..
    you may want to tape them off with high temp tape instead
    the 3 colors gm used
    silver charcoal and black
    any other color was custom sprayed on
      So there are 3 colors?
      Are those the colors you posted for powders, silver, charcoal, and black
      Are they caswell?
      I think I quoted a little low $42.00 a rim, what do you think?
        them colors are factory color...I charge and get 300 a set of 4 75 each 2 coats front 1 coat in the rear and 1 coat of clear
          So when you say factory, you are talking solvent based painting correct?
            give me a call tommorrow . i got tied up today or i would of called ya
