hope this will help a bit on the diff stuff that can be used..
Blast Media Walnut Shells
Use this abrasive to clean internal parts; any of the soft abrasive material left in the working part with break down with minimal damage. Great for gentle paint and carbon removal from ferrous metals. For use at 80 psi max. Be sure to wear appropriate respiratory protection.
Blast Media Silicon Carbide
Silicon carbide has very sharp edges which make it ideal for removing heavy rust, welding and brazing prep, and for glass etching. 60 grit size. Use at 80-90 psi max. Be to sure to wear an appropriate respirator.
Blast Media Poly Bead
Gentle Poly Abrasive will not harm fragile surfaces and produces less dust. Excellent for stripping paint or powder coating from sheet metal and fiberglass Use at 35-90 psi max. Be sure to wear appropriate respiratory protection.
Blast Media Glass Bead
An all-purpose abrasive for all types of metals and many plastics. Best on softer metals like aluminum and brass. Great for cleaning pistons, engine blocks, and light rust removal with minimal dust. Meets mil spec MIL G9954A for size uniformity and is 70-100 grit size. Use at 60 psi max. Be sure to wear appropriate respiratory protection.
Aluminum Shot Media - Lasts up to 1000 times longer than glass bead or aluminum oxide.
Exotic low dust, air cast aluminum shot media cleans without removing casting details. Effectively cleans without embedding or leaving ferrous contamination. Ideal for aluminum castings, radiator tanks, and other parts where a unique sheen is desired.
