compressed air source
  • compressed air source
    Is is possible to use compressed air cyliders as the air source for your powder coating system? A regulator would probablly be needed. what cfm and psi ratings are needed? i think the HotCoat product says you can use compressed gas cylinders instead of a compressor?
    any suggestion?
    thanks, justin
    Re: compressed air source
    Yes, you can use an air cylinder.
    CFM etc. are in the instructions
