the hose holds 5lbs .. but i shoot from 8-10 depending on the powder i am shooting ....
Tip: use a moister filter.. and replace then 1 or more times a month.
Gun Pressure?
Re: Gun Pressure
I set my air pressure at 15psi when I pull the trigger it drops to roughly 10 psi.
Works well.
Bob
8 to 10 # is normal , I adjust my regulator on the gun as needed..some times more, some times less...and if I get really frustrated i put it in hurricane mode....
Gun Pressure?
Hello all, Can anyone tell me what pressure to set the gun at for coating? Are there different settings for certain objects and materials? Thanks all!Tags: None
