i built my oven 3x3x6ft tall, my first attempt to heat it was using a 150,000btu torpedo style heater, it got to 500 in like 4 min. but it is extremely difficult to keep the temp. where i want it. so my question is how many regular electric elements would i need to maintain 400deg. if i preheated the oven with the torpedo? assuming that it is insulated well.
electric / gas oven?
I built an oven that ran around 96cu in for the interior (4x4x6). I had custom made elements built, 4 elements at 3500 watts each, total 12k watts. The oven ran off 220volts with a 60-amp breaker. It heated right up to 400 or 450 like a dream. The problem was that the air temp hit the mark, but part temp took forever. I coated a motorcycle wheel and place it in a 400-degree oven; over one hour later the wheel was still not a 400. I am now in the progress of tearing this oven down for a gas fired one. Also the electric bill shot up $150 per month with the electric oven.
That's an interesting way to build an oven. Two questions: How come the blast from the heater doesn't blow the powder off the part, and is there an outlet somewhere on the other side of the oven?
I have a 75,000 BTU heater I could try. Outdoors, thoughSteve Dold
http://stevedold.com
there is not exhaust on that box.. the powder has never been blown off any part .. But if you want you can put a deflector in it.. to push the force air to the bottom..
that box has not fiber in it it is straight metal.
It is used indoors when i do fire it up i open the doors.but that was in my hobby.. in the shop it is all vent to the outside and in the winter that is my only heat while i am at the shop i leave for the night i turn the heater( the main ) on and it is set at 60f..
