gun problems
  • gun problems
    I am using the hobbie gun and last night while I was coating the trigger stuck! I had to unhook the air line to make it stop, has this happened to anyone? I took the trigger machanizm out of the gun and everything looked good- nothing that could make it stick open. Am I missing something here? I turned the line pressure down real far to finish the piece (I have a pressure regulator on the gun),and just turned the air adjustment screw off when stopping for a second- any help guys!?!
    Save the trees- burn Rubber!
    Some times I have the same proplem too.
    My setup is simple, compressor-regulator-air dryer-air hose-gun regulatoron the gun. I set a compressor regulator about 40psi for the line and since I don't have problem
    I hope this helps
    fr
      sometimes the plunger on the trigger gets dirty ( even if it looks clean) I take the thing apart clean it with acetone every once in awhile..
      Pro-Tech Powder Coating
      93976 Ocean Way
      541-247-8168
      [email protected]
      Gold Beach,Oregon
        Same here, cleaning the plunger parts does wonders. I also use a really small amount of silicone grease on the O-ring.
        Steve Dold
        http://stevedold.com
          My gun opeated fine for the better part of a year, through probably 20-30 square feet of coatings. Then recently, the trigger stuck open, so I took it apart for a look-see.
          The plunger mechansim was coated with powder, and would not slide freely. You can see traces of all 3 of the colors I had been using - black, orange & silver:
          Larger image here
          I looks like small amounts of powder can make it back down the fluidizing tube and into the trigger, so I make cleaning the plunger a regular maintenance chore now.
          Sean
          Seans Zinc Plating page
            one of mine a couple months ago when you would press the trigger would do nothing, you would have to use the twist knob regulator to allow the air to flow, i have started to clean my gun all the time, seeing as this wreaked gun was the one used at school, no-one obviously cleaned it ever, let alone clean the powder on the outside of it.
              I did clean the plunger thing and your right it was pretty dirty. But after I put it all back togather it stille would leak by- I'll try the grease idea, hopefully that works. As for air pressure I normally set my line pressure around 40psi and regulate it on the gun but to get it to stop I had to cut it down to like 20- and the gun didn't work that well like that!
                clean it good and put a dab of grease or teflon on it ..the oil will expand the seal..
                  40 psi seems a tad bit high you might try around 20 and regulate, rember its not an aresol can . ya dont want to blow the powder off and past the part. It's much better to build the powder up slowly and evenly rather than dumping it on..
                  93976 Ocean Way
                  541-247-8168
                  [email protected]
                  Gold Beach,Oregon
                    thanx guys all you help a little grease was all it took!- I was just embarassed because I was doing something for my buddy and he wanted to watch- I don't think he was to impressed! but its all good now thanks to all you experts!
                      mistake # 1 never let anyone see what your doing .. i went out to the shop and there was my brother powder coating parts for his freind.. With my powder .. I pulled the plug on that quick
