I have 2 ovens at my PC shop.
1. A small 18x18x18, frist curing oven and I still use it if the parts can fit.
2. 8x6x6 electric oven, I only use it when coating larger parts.
Now for my problem.
My smaller oven works excellent all the time. I place large items that use all its space and also fill it with a ton of smaller items, my temps range from 350-450f. All the parts cured in this small oven come out smooth like glass.
Now when starting up my larger oven it takes up to about 30hr to get to about 375f/ or 386 which is about 400f in my oven.
If I take smaller parts which could of been placed into the small one the pieces come out fine, if I were to place a larger items in it and cure they come out more orange peeled. Every larger item comes out not as smooth as the little oven when used which is sad because the small oven cost 300.00 and the large oven was 11,000.00
I was told that I am not letting it heat set long enough before I place parts in it. Also was told that the oven temp is off which it is not or maybe the parts are getting to temp too fast and there is not enough time for the flow out of the powder.
I am very confused at this point because the temps are not off and why do the little parts come out perfect if the oven was heat soaked??
Now for my problem.
