Post PC Cleanup
  • Post PC Cleanup
    I just purchased the hobby gun and have a question about cleaning up after you are done PCing. What is the best way to clean the gun and the gun cups? Would it be best (easiest) to get a different cup for each color?
    Since I'll be doing mostly small, small quantity items (2 to 5) at a time, it sure seems like a lot of work for cleanup (if the cups have to be cleaned too) for the small amount of items being done at one time.
    TIA for the tips/answers!
    HobbyTalk Forums: Diecast Collecting - Model Building - Radio Control Vehicles - Slot Cars - Small Engine Repair
    Re: Post PC Cleanup
    Easiest way to clean the gun is to use a air compressor and that usually get's it done QUICK. Usually I use a different cup for each color, and if you run out of cups and want to switch, just wash out the cups and let them air dry for awhile.
      Re: Post PC Cleanup
      Thanks for the info... that helps a lot.
        Re: Post PC Cleanup
        something over looked alot is the oven it self, it's really wild the stuff that can accumulate in there, I try...."heavy on the try" to do a COMPLETE SWEEP when im done, its amazing the places powder gets to and hides, and all it takes is one good puff of wind to ruin a job...I clean my gun right away and the spray area. and if im in the mood i'll wash down the spray area. That dont happen alot, usually rght after i have a white pc job that has purple and red dots on it...
        Pro-Tech Powder Coating
        93976 Ocean Way
        541-247-8168
        [email protected]
        Gold Beach,Oregon
