brass and coldrolled steel
  • brass and coldrolled steel
    I have an Item license plate/turnsignal bracket for scoot that I would like to
    powdercoat black I have used brazing rod for joining the parts will this be a problem and if so is there a cure?
    Re: brass and coldrolled steel
    typically speaking no it will not be a problem i am doing a similar job on a 47 springer frontend. there is a lot of factory brazing on this. if you can get it smooth enough then bead blast and powder away. most brazing is done in the 700-1200 degree range so the cure should be no problem. best of luck bro.
