Re: brass and coldrolled steel
typically speaking no it will not be a problem i am doing a similar job on a 47 springer frontend. there is a lot of factory brazing on this. if you can get it smooth enough then bead blast and powder away. most brazing is done in the 700-1200 degree range so the cure should be no problem. best of luck bro.
