Well as soon as I locate a cheap oven(saw a free one on the way to work i have to go back and check out) I will be making an order with Caswell to get started in powdercoating. I've read the stickies as well as many other sites and wanted someone with experience to tell me if I'm buying everything I need. I plan on doing mostly aluminum enigne parts like valve covers, manifolds, etc. I plan on purchasing
-Caswells gun(havent heard any complaints, good price)
-One roll of the high temp masking tape
-1lb of black,chrome and maybe one other color just to get started
-1 pint of Iron phosphate primer(I should be using this right)
-moisture filter
I like the silicon plug kits but i dont think i can bring myself to spend that much. I already have a sand blaster. I'm gonna weld up tray to sit on top the oven burners to heat up the iron phosphate. Am I missing anything that i really need or am i buying anything i dont. I a total beginner and just want advice.
Thanks
Adam
How do you mask raised letters?
-moisture filter
Thanks
Adam
