raised letter/object sanding technique
  • raised letter/object sanding technique
    I seem to be having a problem and its gotta be user error For right now I've been sanding using a sanding sponge but I can't seem to get away from scuffing the coating. I've also tried using a dremel, talk about a bad idea. It slips after grabbing the edges and the finish doesn't come out uniform unless you take your time and polish everything
    Any ideas to speed up the process and keep it looking good? should I be using a small block with 220 sandpaper instead of the sponge? some of the lines I'm dealing with are 1/16" get to be a real pain to deal with.
    thanks for any help
    Chris
    Re: raised letter/object sanding technique
    For raised letters or lines you need to use a sanding block. A tidbit about using a dremel or die grinder, you must always be aware of the direction of the tool rotation, if you use the tool 90 degrees to the edge or spinning the direction like it was rolling up the letter, it won't grab and go onto the area outside the letter. In machine work it's called climb cutting. SS
      now thats a term i have not used in about 15 years.
        why are you polishing after coating ? it a lot easier doing it first.
        for raised letters
        here is what I do
        clean and blast the part
        I use a hand polisher called a MOUSE from SEARS
        I start with 220 ( 100 if it's too rough)
        then 600
        then 800
        then with a 3000 RPM hand polisher use black emery on sewn
        then white rouge on loose
        and you are set and won't take you over 20 mins from start to finish polishing the letters
        clean with thinner
        outgas
        tape out the letters with high temp green tape
        coat
        remove the tape
          now thats way too much work I'm lazy and all I'm looking to do for right now is just clean the raised objects after I'm done coating. Thanks for the advice though. I've written down in case someone wants coated and polished stuff.
          thanks for the advise guys and I'll try out a sanding block this weekend.
            Chris:
            If you're patient, try an x-acto knife. Just scrape away the top of the raised lettering. That's how I restored this 60 year old data tag:
            _Click for larger image
            Sean
            Seans Zinc Plating page
              WOW! now that took some serious patience and time. HAHA I barely have enough patience to let my stuff cure fully, I doubt I'd ever be able to get through that. I gotta take my medicine any day I want to powder as it is. ADD sux
                That tag didn't take much time, about 30 minutes. You just have to be careful with the knife work, that's where the patience pays off.
                Sean
                  Blast your part and then powder it. Here is the trick, take your pointer finger, or which ever finger you feel most comfortable with, and slowly dab/drag the raised letters one at a time until the powder is removed. I did this with a valve cover after I did the candy red and it worked great.
                    that's agood idea
                    a Q-tip might work better than the finger
                      Originally posted by jtagger19
                      that's agood idea
                      You have to watch anything that has cloth like a Q-tip or rag. One little strand of fiber can move around powder where you dont want it to.
                      Unorthodox Creations Powdercoating
                        I've tried Q-tips and they don't work as good as your finger- all the cotton strands start to fray and you end up touching the surrounding areas- the finger works best
                        Save the trees- burn Rubber!
                          I was trying to post at work about the q-tip. It acts like a magnet. I was going to try and wet it but just used my finger.
                            its alot easier to first polish the letters out, spray and then place in the oven till it flows out. Let the piece fully cool, use a scotch brite pad or 2000 grit sand paper to remove the powder on the lettering and rinse off, do a full cure after that.
