I just ordered and got in from Caswell the Green High Temp Tape. I am not using it right or it is not doing what expected it to do.
I am wraping it around some fairly easy turns, about like going around your finger. It will not lay down and stick. Then after curing it, I have to cut it off with a knife? Maybe I'm wrong but I thought high temp masking tape meant more than it would not burn up. I thought it would be user friendly after being in the oven and actually mask the edges.
Should I be using something else. I have used regular painters masking tape. It works around corners and curves just fine and then you have to clean up the residue.
Anyone have an idea on what I could use that will work?
