filling pits
  • filling pits
    I have a set of NEW calipers, bright silver finish (does not burn off). PC'd the inner bracket with lollipop blue & turned out great! Main body has pits in the casting (cast iron) I tried solder, but I can't get it to stick. What can I use to fill these pits? I'm trying to forego the chrome base.
    mach
    TSA Custom Metal Finishes
    Live fast, Die sideways
    Re: filling pits
    As an afterthought, I think they're small enough that they won't show dark spots, could I use Liquid Steel or something similar?
      Re: filling pits
      Yep, JB Weld works good too..
        Re: filling pits
        I'm having a problem with pitting too! I have a rim and pitted all over. I even used lab metal to the crater area, but you can see the lab metal fill under the chrome powder. I outgassed and it didn't help. What do I do about this?
          Re: filling pits
          JB Weld is good up to about 600 degrees, and it sands fairly easily too.
          Leo
          www.tinmans.net
          "Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming -- WOW--What a Ride!!!" ----- Unknown
            Re: filling pits
            Thanks guys!
            I got some stuff from work "P.M.C. Super Quick Set". I'll try JB weld too, see which works best.
              Re: filling pits
              OK, Used the stuff from work, let it set & gave it a light wire wheel to match the texture. Used carb cleaner to clean it,(read that somewhere in here) heated it at 300f to burn it off. I coated it, cured it, & came out with fish eyes. DOH! Lightly sanded it with 200 grit just to smooth the fish eyes, recoated it, cured it, came out GREAT! The only thing was(back to the pits) it did show the dark spots. Not very noticeable, but they're there. SO.... if you have to fill pits when using translucent colors, ya gotta put the base coat on it! As a side note, blasted & cleared an old rotor I had laying around, makes a killer display base! One of these days we'll get a digital camera!
              mach
                Re: filling pits
                Something you might try also is when you use brake wash or any solvent, hang the part in the oven at around 150* for 10 to 15 minutes to make sure all the slovent is out of the pores. I have had brake wash cause fisheye before I started drying in a warm oven.
                SS
                  Re: filling pits
                  brake clean instead of carb clean. carb clean has tolulyene(spelling?)in it and it leaves a residue that is hard to get off. brake clean works good though. also if you have the safety gear mek works great but it pretty bad stuff.
                    Re: filling pits
                    sswee, did that, at 300 for about 10 minutes. Think the problem was the Gumout instead of Brakleen (copyrights, of course). I'll stick with the Gumout, don't want "bad stuff" in my basement!
                    Thanx for the info bothofyas!
                    mach
                      Re: filling pits
                      mach
                      oops, meant brakleen
                        Re: filling pits
                        Avoid cleaning parts with carb cleaner. Most carb cleaners contain silicone. Try using brake cleaner instead.
