Stripping......
  • Stripping......
    Whats the best stripper for removing the clear coat from factory aluminum wheels?... i really dont wanna sand blast.
    If it jams; Force it. And if it breaks it needed replacing anyway.
    I can go from 0 to "What seems to be the problem Officer?" in 3 seconds."
    Re: Stripping......
    try aircraft stripper that you can get at most auto parts stores.
      Re: Stripping......
      KZjim,
      If it's clear coat you can use Aircraft Paint Stripper. If it's anodized you can use EasyOff Oven Cleaner!
      John
        Re: Stripping......
        Thanks guys.. i have some aircraft stripper.. just want to ask first.... didnt wanna waste time and material.
          Re: Stripping......
          i have some stripper and it still is not fully coming off. anything stronger?
          http://www.illwillinc.com/
          PC'ing -> trods
            Re: Stripping......
            myillwillinc,
            How old or new is your stripper?
            You may have to use more that one coat!
            John
              Re: Stripping......
              i bought the thick stripper that needs to be brushe don and it worked alot better...
              PC'ing -> trods
                Re: Stripping......
                BIX You can get it at any home depot. It works good but you have to use a brash wire brush.
                Powder coating / Polishing and much more!
                www.latenightcustom.com
