I have a customer rim that had flaking, peeling chrome plating. I got it stripped and now there's all these pits and craters. I went about doing the rim like I normally do and used glass bead media for the chrome. I outgassed at 450 for 30minutes, let it cool a bit then hit it. The rim turned out like this.
In the pics you have the pit areas and the bubbling areas. I sanded down some areas and it's not the media. I did another rim exactly the same, but with no damage and it came out perfect.
Could it be that even with outgassing the pitted areas are still outgassing during curing?
Should I outgass a longer period at a higher temp?
or should I just sand it down and hit it cold?
