Hi folks! Hope everybody is having a great thanksgiving week.
I'm building an oven similar to the one Viper59 built here:
http://www.stivermotorsports.com/id44.htm
(thanks for the inspiration Jim) but I do not have 220V available. Therefore I am making a few changes to hopefully enable me to run the oven on 120V:
1. Making the oven smaller (internally it's 40" long x 20" wide X 36" high).
2. Using 5052 aluminum.
3. Building the interior so that it is insulated from the studs using the 1" wide insulation tapes.
4. Using multiple 120V elements, using two or more circuits.
My main question is this: Does it cause any problems or defect in the finished product if the part is placed in the oven cold, and it takes 20-30 minutes to get from cold to the proper cure temperature? I don't think this thing is going to be heating up super-fast on 120V, and with the top-loading lid, pre-heating the thing isn't going to do much good.
Thanks! - Steve
This oven will be used mainly for newly-assembled bike frames, or for paint storage if it does not work as an oven
Thanks! - Steve
