lollipop red question
  • lollipop red question
    have any of you added a red flake to the lollipop red? any pics?
    SouthWest Powderworx
    Tyler Nutter
    5054803934
    www.swpowder.com
    myspace/swpowder
    [email protected]
    sigpic
    Re: lollipop red question
    You mean silver flakes in red? or fire mist additives, then yes. I have used them before and to really get a nice effect do it in the candy, then top coat with clear to underlay the fakes, so companys will sell you stuff that will bump out in the coating after curing.
      will the red cover the silver in the silver flake? or will the silver flake look silver? I'm after a red metallic effect.
      Tyler Nutter
      5054803934
      www.swpowder.com
      myspace/swpowder
      [email protected]
      sigpic
        Your original thought was correct - you want the red sparkle additive, not the silver.
          thanks Caswell.
          Tyler Nutter
          5054803934
          www.swpowder.com
          myspace/swpowder
          [email protected]
          sigpic
            When I liquid paint, my little "trick" is that I use pearl mid-coats alot. One that I do alot when using candies is using a silver pearl, then when the candy goes over it, it will sparkle the color or the candy. (looks really killer with silver and red candy over black!)
            Save the trees- burn Rubber!
              thats the effect I was talking about.
                I don't want to put any base down as it is going over half polished billet. thanks for the replies.
                Tyler Nutter
                5054803934
                www.swpowder.com
                myspace/swpowder
                [email protected]
                sigpic
                  look for the bike frame in my pictures, i did it in the lollypop red with gold flake, it turned out great, it did however lighten the red a bit, instead of the usual dark lollypop color, it looked great tho, go for it.
                    I can't really see the gold flake, but otherwise the pics look great.
                    Tyler Nutter
                    5054803934
                    www.swpowder.com
                    myspace/swpowder
                    [email protected]
                    sigpic
